Need box design for 2 alpine type r's
04tahoe
TN
I'm in desperate need of a box design for 2 alpine swr-12d4 in a 04 Tahoe. Running alpine mrx-m240 at 1500 rms. Port back for sure not sure if sub's back or up is better option. I listen to mostly rap, rock, and some dubstep.
Sub specs:
CAR AUDIO,
VIDEO & GPS
CAR SECURITY
& AUTOMOTIVE
MARINE,
MOTORCYCLE & ATV
HEADPHONES
HOME & PORTABLE
AUDIO
DEALS
BLACK FRIDAY EARLY ACCESS
Get 5% Off
Go »
Alpine Type-R SWR-12D4
3000W Peak 12" Type-R Series Dual 4-ohm High Performance Subwoofer
4.6
88 reviews
Out of Stock
Dual 4-Ohm Dual 2-Ohm
Photos (5)
Videos (2)
Your Price: $159.99
Notify Me
Low Price Guarantee
FREE Shipping on Qualified Orders over $49
Description
• 1000 Watts RMS
• 3000 Watts Max
• Reinforced parabolic cone structure
• Durable High Amplitude Multi-Roll santoprene surround
• Cast aluminum frame with integral shorting sleeve
• High-grade strontium ferrite segmented magnet assembly
• Integrated 8 AWG push terminals with VC jumpers
Read Full Description
Features & Specs
Subwoofer Specifications
Subwoofer SeriesType-R (Alpine)
Subwoofer Size12"
Peak Power Handling3000 watts
RMS Power Handling1000 watts
Voice Coil(s)Dual
Impedance (Per Voice Coil)4 ohms
Voice Coil Diameter2.6"
Frequency Response24 - 200 Hz
Sensitivity84.9 dB
Xmax (millimeters)20 mm
Subwoofer DesignRound / Circle
Main Cone ColorDark Gray
Woofer CompositionKevlar Fiber
Woofer SurroundSantoprene Rubber
Subwoofer GrilleOptional (Accessory required and sold separately)
Alpine KTE-12G
Re-Cone Kit AvailableNo
Recommended Enclosure Specifications
Recommended Enclosure TypePorted / Vented
Sealed
Minimum Sealed Box Volume0.55 cubic feet
Maximum Sealed Box Volume1.00 cubic feet
Minimum Ported Box Volume1.0 cubic feet
Maximum Ported Box Volume1.50 cubic feet
Top-Mount Depth6-3/8"
Cutout Diameter10-7/8"
Shallow Mount InstallationNo
Electromechanical Parameters
Free-Air Resonance (Fs)28 Hz
Equivalent Compliance (Vas)46 liters
Total Speaker Q Value (Qts)0.48
Electrical Q Value (Qes)0.52
Electrical Resistance of Voice Coil (Re)3.8 ohms
Mechanical Q Value (Qms)6.04
Sent from my SM-S975L using Tapatalk
Come on somebody help me out. I work in a body shop so tools and ability to build aren't an issue just don't have access to computer just my phone right now. Im not sure about how to get my ft³ with the port factored in im probably overthinking it but i just want to build the perfect home for these two in my tahoe
search up torres box calculator
enter in your max dimensions and experiment with the port along with possible displacements via bracing or subwoofer.
Main rule for beginners is to keep port area per foot around 12-16 for slot. Round ports is 9-13
How does this look? Wanting about 2.7ft³ net volume wasn't sure how to factor bracing so just set it to 2.8ft³. Any suggestions would be greatly appreciated
you'd want to almost double what you have volume wise for two 12s and I told you 12-16 port area per foot. You are at 5.33
If it is a slot port, you need to put 3 for common port walls because thats how many wall of the box is used for the port. Displacement for two type R 12s should be closer to 0.20 not .1
If you want it stronger, you can double baffle the box as well. which means you put 1 in "# of extra baffles"
Ok it'll be tommorow before I can get back on the program. As far as volume recommended net volume for one is 1.38ft³ so I was just doubling that is there something I'm missing? And I see my mistake on the p.a.p.f I was looking at the wrong parameter
How much power you feeding them? 1.5-2 net per works very well. I can help you out with a design and cutsheet.
Sent from my SCH-I605 using Tapatalk
Proper port area takes up box size. Your current port is 1/3 of whats needed and a bigger and longer port will eat up more than a cubic feet. Hit up CSCstang for a design. He did one for two type R 12s that got loud before in an SUV.
1500 watts so 750 each before rise.
Internal port volume and speaker displacement, will take up some internal enclosure volume. Keep that in mind as you get that enclosure deigned. Woah, that rhymes! I just simply don't have the time. I took a step backwords and stepped on a dime. Oh man I'm on fire!!
Wired 4 ohm at 1500 rms. Going in a 04 Tahoe
04tahoe
04tahoe
TN
04tahoe
