Need box design - 10" SoloX Ported
Yeah, here's a thought //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :
Haven't done any calcs on it yet and I know there's not enough clearance for the magnet, but this is something along the lines of what I was thinking.
There is room on the sides but the box will have to have some indentions on the bottom corners to fit around the seat latches. Could probably grab 3" on each side - this will allow for me to mount the amps on the box as well - that is if you can design it to clear the magnet for mounting.
Yeah - that will be my only other option if this doesn't work out, but I at least want to get the side firing to a point where i can see and hear if it sounds like $hit - if it does then I will put those 10's in and push them with the amps I have.
I really like that. He doesn't have enough room with that design to mount both amps on one side but he could do one on the front and one on the back. That's a really nice design.
I was actually thinking of mounting them on my rear hatch - which will take some modification that I'm not sure I want to do.
If not I could mount one on each side
Brian ~
Do you build as well? or can you recommend someone for this. It can be unfinished as I was planning on getting it poly sprayed to seal it up real nice.
Be sure to post build pics man, that's gonna be a nice box.
I definitly will, I plan on posting progress pics of the install. Will take sometime as I plan on doing it myself.
As for the box build - I am by now means a carpenter and do not pretend to know how either. I'll leave that to the experienced.
And as for the amps - I may want to build an open amp rack on the bottom of the box which will raise it up approx 4-5" but is something I can have one of my work carpenters do once I get the box done.
Any takers on building this - obviously I am willing to pay a reasonable amount plus I will throw your advertising on my sig if interested. Brian's will all ready be there.
If you raise the box up then the straight part of your box will be into the slanted part of your seat. Keep that in mind.
richierich75
richierich75
BMORE
richierich75
