need an enclosure design, who still does them??
[quote name='The_Dealer']Post your max dimensions, and what subs/amp you're running and I'll work on one.
Sent from my Motorola 2950 Special Edition 3w.[/QUOTE]
Thx for the help.
49"W x 20"H x whatever is needed up to 86".
AQ3500.1d (4300@1)
4 10" CT Sound Meso
The box will be in a blow thru in an Avalanche. So subs & port (would ideally like a center slot port) would be on the same face forward. That must be 49" x 20" to fill the blow thru area. LOW tuning please. Right now I have 2 15" in 10.5 cubes @28Hz. 30Hz is the highest id like to go with them please.
Let me know if there is anything else I can give you and PM me what you'd charge for a cut sheet as well, thanks.
I've actually done exactly this.... I'll post some pics of my setup later. Made a wall and covered it in bed liner. Looks great, BUT I kinda messed up when building the box.
Please check out my post I just posted.
I'm looking to get a design/blueprint made with these same measurements. I'm thinking I can get away with 50" wide but might want to go 19" on the height.
Oxsign, Where did u measure from? With my box currently installed I can't measure from the opening in the cab I just got a rough measurement from the back of the bed by the tailgate.
The dealer, if u can help me out on this project also with some box plans/blueprints it'd be much appreciated. Let me know how much u would charge me for something like this. I'm capable of building this, I just want to make sure I have the right dimensions and want to do it right this time around instead of wasting my time and money again on a subpar box for my subs.
I haven't forgot about it, been working on a design. Been swamped with boxes, now that it's tax time everyone wants to get loud.
Sent from my SM-G900A using Tapatalk
I can do a much better design by using a beauty panel and making the box shorter. I'm not too crazy about the port width/height ratio
That looks great, thank you. A lot shorter depth wise than I thought it would be. That's pretty much what I was looking for. I'll be putting a beauty panel on it to secure it to the truck & locks when all is said and done. What was the final cubes & tuning by chance?? What do I owe you for this??
Sorry, I thought I listed it. 2.06cuft@30.16hz with 16.82sqin of port per cube. Should do pretty well. BTW, that's after all displacements.
I've had a long week. That was per side/chamber, so each sub will see just over a cube each. I can make it a little larger of you'd like, but will work **** good as is. You don't owe me anything, just post pictures of the build lol.
why not just go 2 15s? 4 0s are a waste of money and wont be as loud as 2 15s..
It's completely install dependant. The 4 10's would have a s**t ton more motor force than the 15's, and should handle more power.
oxsign
No Affiliation
oxsign
Orlando, FL
The_Dealer
