Need Amp/Sub help!
Cali_Screw
I have a Rockford Fosgate Bd 1000 amp, it plays 1000 RMS at 2 ohms. Im looking into getting 2 12" RE audio SE subs that claim to be 600 rms so a total of 1200 rms. Do you think i will not have enough power or should i be fine to push them where they will sound good?
You should be fine. those rockfords are underrated by a tad, so it should be a close match. set your gains correctly and youll be fine.
Yea i know these year Rockford were kick ***...
thank you for the help...
as for gain, im new to tuning the system, how would i go about setting that?
get a digital multimeter, unhook your subs and stick the dmms neg a pos probes in the amps pos and neg speaker terminals. turn your hu 3/4 way up and play a 60hz test tone or something you normally play that has long steady bassline, and turn the gain until the dmm reads 44.7v thats the voltage you need for 1000rms into 2 ohms.
wow, i had no clue! thank you very much,
do i turn the head unit down on sub woofer level?
and i also have a bass nob what do i do with that?
Cali_Screw
Cali_Screw
Rancho,CA
Cali_Screw
