Need amp ideas
x2 on the 2 channel thing.
do you have this subs already...?
There's alot of options i like rockfordfosgate..
I don't see them talked about much i think its a usa thing lol.
I like rockford amps too (& own a few) but they're expensive. The audioque is good quality @ a very reasonable price, own those as well.
ok how about this MBQ 1500 vs Audioque 1200, are they both stable at 1 ohm? also my speakers are 4ohm that means i can run them at 1 ohm a peace right?
You are very confused on speaker impedance. Dual 4ohm subs means they can each be wired to 2ohms, or 8ohms. You can also wire them together for a final load of 1ohm or 4ohms (mono). But no, you cannot wire each one to 1ohm.
859
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Jayy
Jayy
tampa fl
Falcons
maylar
    Jun 2, 2024
    Jun 1, 2024
