need aero port help
jailhouseracer8
BassHead
I just got my 2, 4" aeros today, and all i have left to do is install them in my box. This is my first go-round with aeros, so i have a couple ?'s.....Does the inner flange screw down inside the box? I was thinking so because it would look funny mounted externally. 2nd, i measured both ports, assembled, end to end, and they are 18". Should i leave them both at 18, or should they be different lengths from each other? the box is already together, 2.5 cubes after sub displacement, sub up, ports back.....any help would b awesome! thanks
cool, so the box side flange does mount on the outside....and yes, its 2.5 cubes, both ports are 18". didnt kno if i should try them at the length they are now, and if it dosent sound good, cut an in. or so off at a time.
the ports mount to the OUTSIDE of the box. IF you'll notice the interior flare does not have the mounting flange and is used to trace the cutout for mounting. The external piece has a flat flange that mount to the box. If you are doing EXTERNAL PORTS, then yes you mount the Extenal piece to the inside of the box and the port is outside the box.
You want the air to have a smooth trip. Not so smooth if you have the box, then the port.
well, got the box all done, all wired up, and ready to hook up! I did have one last question. When "trimming" the ports, to desired length.....should i cut equal amounts off of both ports to keep them equal length, or can i just trim one port?
the ports need to be the same length....is that what you mean?
yeah...when trimming the ports make them the same length.
same length. refer to the calc I posted.
jailhouseracer8
BassHead
jailhouseracer8
Odessa, Tx.
jailhouseracer8
