need advise on wiring my subs
crzybob77
Alright, i am going to be getting two 12" single 4ohm voic coil subs. I want to wire them as a 2 ohm load on my amp to get the most out of my class D mono amp. I know that they need to be wired in parallel to do this. I talked to some people at crutchfield about the wiring diagram that they have one their site :
http://www.crutchfield.com/infocenter/car/S-wx2Z5XtM7R7/amplifiers_faq.html
It is near the bottom of the page.
I want my amp to be 1 channel (bridged). So, they said to put 2 wires into the positve and 2 wires into the negative terminal on the amp and then take those 4 wires and hook them to alll the positive and negatives on the sub. They said this will make a bridged 2 ohm load. Does this sound correct?
one more thing..... my amp is a US acoustic class D mono sub amp. It is 600 x 1 at 2 ohms. So, the 2 subs will get 300 watts a piece when wired in parallel like i explained before, right?
Yeah that sounds right...Also it sounds like they built the amp like JBL with two speaker terminals.. The terminals both pos and both neg are connected internally so you can hook them up to one set or both and not have any worries.. just an FYI
Mike
just wire subs like the website instructed and you will be getting 300w to each.
p.s., i also added a comment to your web page.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
293
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
302
crzybob77
crzybob77
Richmond, VA
infinity311
winkychevelle
    May 24, 2024
