Need advise on two 12" subs
fire919
I have 2 american bass ph4000md and i want to run each at 1ohm
the enclosure i have is as below. my budget is no more than 300 per sub. and i would like as much sq/spl i can get for that price.
☞ 5/8" HDIP
☞ Height 14.50" x Width 29.50" x Depth 19.3/4"
☞ 1.90 Cubic Ft. Air Space ( per side )
☞ Woofer Mounting Depth x 19"
☞ Tuned at 38 Hz
AMP specs
1 Ohm Stable Class D Mono Block Amplifier
Rms at 1 Ohm: 2000 Watts
MAX at 1 Ohm: 4000 Watts
Frequency Response: 10Hz ~ 220Hz
Input Level: 5V ~ 0.2V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 40Hz ~ 220Hz
Switchable Bass Boost: 0dB, 6dB, 12dB
fire919
fire919
the bronx,NY
fire919
