Need advise on two 12" subs
  • 4
fire919
I have 2 american bass ph4000md and i want to run each at 1ohm
the enclosure i have is as below. my budget is no more than 300 per sub. and i would like as much sq/spl i can get for that price.
☞ 5/8" HDIP
☞ Height 14.50" x Width 29.50" x Depth 19.3/4"
☞ 1.90 Cubic Ft. Air Space ( per side )
☞ Woofer Mounting Depth x 19"
☞ Tuned at 38 Hz
AMP specs
1 Ohm Stable Class D Mono Block Amplifier
Rms at 1 Ohm: 2000 Watts
MAX at 1 Ohm: 4000 Watts
Frequency Response: 10Hz ~ 220Hz
Input Level: 5V ~ 0.2V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 40Hz ~ 220Hz
Switchable Bass Boost: 0dB, 6dB, 12dB
114
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
97
434
336
fire919
fire919
the bronx,NY
fire919
    May 12, 2024
Brendon Jenness
    May 11, 2024
