Need advice
tjustin7
Greetings all,
I have an 2003 OLDSMOBILE BRAVADA, with the stock 6-disc BOSE cd player.
Recently it's malfunctioned with an error "PLAYER ERROR" and seems to be unable to eject disks, and cannot eject the disks. I was able to physically pull the stuck disk out, but the unit continues to try and eject a disk, fail, and then give the error. The AM/FM radio works fine.
I went to a "major car stereo store", and they said because I had a 2003 GM / BOSE stereo system, I needed:
a standard CD Player - $100-150
an adapter to convert 12v to 0.3v due to the BOSE system - $150
a steering while adapter so the volume controls on the steering wheel work - $120
Brackets, etc, for a total of
$475 after taxes.
Just to play CD's in the my car like I could before.
Is this for real?
Surely other people have had this issue?
He suggested NOT getting a unit from a junkyard, as it might not work, and, having been off for so long, may not work due to anti-theft.
Note the stereo has an AUX button on the front, but no AUX input on the front of the unit.
Is there some other solution that doesn't cost $475 to make this so I can play CD's?
Is there some hidden AUX input on the unit that i could somehow plug an iPod or something into?
Thanks for any advice/input.
PS: This is how I induced the PLAYER ERROR, if you're curious:
Switch Disk 1, played for a few seconds
Switch Disk 2, played for a few seconds
Switch Disk 3, played for a few seconds
Switch Disk 6, played for a few seconds
EJECT Disk 6,
PLAYER ERROR.
The unit makes a noise like it's trying to switch trays ("whir whir whir"), then a sound like it's trying to eject ("KNEE KNEE KNEE"). Then it reports "PLAYER ERROR" and switches to AM/FM.
I was able to pull out a disk, but the unit still sees 6 disks, and still seems to be trying to do that same operation (switch, eject).
The prices quoted to replace the head unit with the shop's parts look pretty outrageous. $120 to retain steering wheel controls? Check with another shop. I do not recommend you pursue repairing this radio unless you really have an aversion to aftermarket radios.
If those prices are installed then they are average shop prices most shops charge $85 an hour plus But it does depend on the parts. Even as a dealer the parts can be expensive in some cases
The prices do include installation ("$1 install").
Can anyone comment regarding the anti theft comment?
The main purpose of the CD player is mostly to play kids music... so no Audiophile stuff required here.
In other words, $80-$150 for a junkyard CD player is very much tempting compared to a $475 basic audio system.
Were there any other choices besides those two?
FYI,
I FIXED my "PLAYER ERROR" issue with my original stereo.
After physically removing disc 6 out of the unit, the device still indicated PLAYER ERROR.
I ended up pulling the fuse for the radio multiple times. Each time, the player cycled the discs slightly differently.
After about the 3rd or 4th time, it started working.
I cycled through all the trays with no problem (including the empty tray 6, which then cleared and indicated it was empty).
Thanks everyone for the advice regarding a new stereo.
I'm going to keep my $475 for now and hold out until the unit is totally dead.
I'm also going to avoid using Tray 6 as I think that's where the problem stemmed from.
Thanks.
552
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
651
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
919
tjustin7
tjustin7
Troy, IL
tjustin7
