need advice please
Q1-3500D.1 Amplifierit will run@.5 all day ..you will ve way more happy than with 2 hifonics
---------- Post added at 01:59 PM ---------- Previous post was at 01:58 PM ----------
Soundqubed ...used to be audioque....my car is all audioque front to back im very happy with every one of their products
so i can run that amp on .5 all day? i was looking to get 2 1ohm ia dp and either run them at 2 ohm or .5
so if it can run .5 daily that would be sick
Here Local the Extreme are $143 out the door without a core:santa:
The platinum ran me $179 without a core after tax, still a good price. I've dropped $180 in worse ways, plus I sold my other walmart lead acid battery that was a couple years old to a customer of mine from work for $50
so if i strapped 2 brz2400.1d at 1 ohm each it would make it 2 ohm or .5 ohm correct? does anyone know if these would even be stable at .5 ohm?
---------- Post added at 12:12 PM ---------- Previous post was at 12:11 PM ----------
You would need 2 d2 subs to run at 2 +.5 ..1ohm subs will give u 1 ohm and .25
so if i got 2 1 ohms subs it would do 1 ohm or .25 ohm?
I would get another brz tbh for now and seee...it might be enough for you..if not sell them
This is an excellent Idea here..Running below 1 ohm daily can get pretty heavy on the electrical..deff have to have excellent electrical to run safely daily any lower in my opinion.
Yes..and if u strap amps with 2 d2 subs each amp would run at 1ohm
If you run 2 amps/BRZ..you can run 1 amp per sub @2ohms or 1 ohm,and play it safe on a daily setup,with your electrical.Anything lower, and Id be competing.Run over at 12volt.com, and click on sub woofer diagrams, and play around with # of subs/ohm loads and decide on what ohm load you want to runat and what subs you want to run,that will be compatible with what you want.Make a decision on what ohm load you want to run.I believe you said 2 ohms in the beginning,in which is where Ill be going back to in a couple of months from a 1ohm load.Bookmark that sight,as it has all kinds of information as well
444
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
554
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
861
vibe
vibe
Prescott, AZ
audiobaun
    May 24, 2024
