Hello and Thank You for viewing this post!
I recently bought an 89' Ford Ranger XLT with a 350W kicker amp and two ten-inch (standard model) MTX Subs.
I installed the system myself but had a pro check over everything to make sure it was ok. I knew I needed a bigger amp to get the most out of my two MTX's. The Pro recommended an 1000W AMP at minimum, probably 1200W.
Browsing through amazon I found this subwoofer:
Pyle PLA2378 2-Channel 2,000-Watt Bridgeable Mosfet Amplifier
It's a bit bigger than advised, However I think that may be a good thing as I'm hoping to upgrade to a couple of Rockford's in the future. My question is this: Will I (LIKELY) need another battery or a HO Alternator to power the AMP? Even if I use it on low settings? What about a 1200W AMP? Would I be able to power that without further upgrades?
My truck has no problem using the 350W AMP of course, and my battery is good. The truck has had a lot of work done on it. It may, perhaps, even have a newer better-than-stock alternator installed.
Thank you for your help! //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
