Need advice on first sub system
Greg_227
Basically I just want to know if I'm going in the wrong direction with anything.
2 12 inch pioneer champion pro 600 watts rms
Big 3 upgrade
4 gauge wiring kit
Hifonics Brutus Brz1200.1d 1200 Watt RMS at 1 Ohm
Bbox E12DSV Dual 12-Inch Shared Vent*
I have a stock 2008 Chevy malibu.
Will I need a new battery/alternator or is the big 3 enough?
the box for sure is a poor decision. prefabs are never great but, the Bbox ones are especially cheap and weak as well as poor sounding. build one or have someone build you one. i'd also start out running 1/0 instead of 4ga. this way when you want to add an amplifier and change the interior speakers (as well as upgrade your substage, it always happens), you don't have to rerun the power wiring you simply add distribution. big 3 should do the trick with that equipment and vehicle. if you wanted to take an extra step find a local shop to rewind the alt to a higher amperage.
Greg_227
Greg_227
Dallas, TX
AFS585
