Need advice DMM testing resistance.
I think I just caught your problem: if you are running EACH of the subs to their own respective + and -, I think the amp is not seeing that as a 1ohm load, but a 4ohm load. I could be wrong, but try running BOTH the + to the left side to one + terminal, and then BOTH the - to the right side on one - terminal. That should make it run at 1ohm.
It's a mono block so that don't matter. It's just like linking them in the box.
But won't the amp see different loads depending on how you hook it up? I'm honestly not sure just trying to throw some advice out there. On my AQ2200 it is a little confusing, but I know I have mine running at 1ohm with only one + and - taken up.
They are linked internal. It's the exact same thing.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
621
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
703
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
4K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
949
i2ain2thunder
i2ain2thunder
st paul, mn
tommydh
Dan Medina
    Jun 17, 2024
Doxquzme
    Jun 15, 2024
