you have 2.13ft^3 net before sub and port..assuming 3/4" wood is used....
the mag displaces about .15ft^3..
so you are now at 1.98...(i'll get to the port in a minute)
a slot port will be hard to figure with that tuning/box side due to length. so i'd recommend 3 ports, 3" in diameter (inside). fire the sub up on the driver's side and the ports firing into the passanger side rear door. nice loading area and you avoid the rear seat mounting feet on the driver's side.
so, 3 ports, each 3" diameter x 35" long will give you a net box of ~1.4ft^3 tuned to 32hz....that's using schedule 40 pipe. if you use schedule 80, you'll get a bit more volume, and they'll proabably fit a touch easier. use liquid nails around them on the inside to keep them firmly planted.
btw,
here's a nice port calculator to help you out. it's really close. if you decide to use a flared port, just plug in the inside dimension of the non flared part, then add an inch to compensate for the flared part.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
