Need a Positive battery Terminal
These work perfect,with use of Copper ring terminals, and heatshrinked.Use any size wire needed with ring terminals,I run to all post on both my batteries in my truck,and check all my connections once a month if driving daily for security,use a socket to tighten,rather than the phillips,to get it tight!XS is made by Stinger fyiXscorpion BTRG Gold Plated Any Gauge Cable Battery Terminal | eBay
do you use one neg and one pos?
Yes I do,for both batt in my truck, and work very well,and look half *** decent as well..You can find a pair rather than a single on ebay,for around $20 shipped, and as stated earlier XS is made by Stinger,so it is good quality
i got these for sale
I got the stuff together finally, and getting ready to start replacing battery terminals and working on Big 3 upgrade. What a difference. Only got the positive termiinal done, ran out of ring terminals. Fits the battery post much tighter, and using the ring terminals makes it a lot easier to connect/disconnect the power wires when needed.
Thanks again to audiobaun for recommending these. I can't get the mention quote thing to work.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
113
184
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
137
489
sbelew
sbelew
New Port Richey, FL
sbelew
audiobaun
    May 19, 2024
    May 19, 2024
