Need a new 4 channel Amplifier...considering these
BreakinTHEbank
Oz
Looking for a new amp to power my fronts and mids.
These are the ones I'm looking at:
Boston Acoustics GT-4100
Number Of Channels:
4 Channels
4 Ch. Power @ 4-ohm (CEA-2006-A):
100 Watts x 4
4 Ch. Power @ 2-ohm (CEA-2006-A):
150 Watts x 4
Mono Power @ 4-ohm(CEA-2006-A):
300 Watts x 2
Mono Power @ 2-ohm (CEA-2006-A):
450 Watts x 2
Mixed Operation Power (CEA-2006-A)
100 Watts x 2 (4ohm)& 450 Watts x 1 (2ohm)
4 Ch. Power @ 4-ohm (12vdc)
85 Watts x 2
Frequency Response (-3dB):
10Hz-95kHz
Signal to Noise Ratio (A Weighted):
>100dB
Lowpass Crossover:
12dB Adj. (50Hz to 350Hz)
Highpass Crossover:
12dB Adj. (20Hz to 250Hz)
Q-Tune:
Adj. HP Q (0.707 to 1.6)
Kicker ZX650.4
RMS Power Rating (@ 14.4V):
  • 4 ohms: 120 watts x 4 chan.
  • 2 ohms: 170 watts x 4 chan.
  • Bridged, 4 ohms: 325 watts x 2 chan.
  • Variable high-pass filter (50-200 Hz, 12 dB/octave)
  • Variable low-pass filter (50-200 Hz, 12 dB/octave)
  • 2yr Warranty
Infinity Kappa Four
Specifications
• 125W RMS x 4 channels @ 4 ohms
• 150W RMS x 4 channels @ 2 ohms
• Frequency response: 10 to 75kHz (-3dB)
• THD + N: 0.05%
• Signal-to-noise ratio: 85dBA (reference to 1 watt)
• Signal-to-noise ratio: 106dBA (reference to rated power)
* CEA-2006A-compliant
Soundstream REF4.760
Channels 4
RMS Power @ 4Ω, 14.4V 4 x 115
RMS Power @ 2Ω, 14.4V 4 x 155
RMS Power @ 4Ω Bridged, 14.4V 2 x 380
RMS Power @ 1Ω, 14.4V -
Total Harmonic Distortion (4Ω power) 0.02%
Frequency Response 15-50kHz
Signal-to-Noise Ratio (4Ω power) 102dB
Damping Factor (100Hz, 4Ω)
Dimensions: 2.25"h x 9.875" 55mm x 250mm 20.25" 514.5mm
Ch. 1&2 HPF/Hawkins/Subsonic (12dB Slope / 0-10dB Hawkins Boost) 15Hz-4kHz
Channels 1&2 LPF* (12dB Slope) -
Channels 3&4 HPF* (12dB Slope) 15Hz-4kHz
Channels 3&4 LPF* (12dB Slope) 50Hz-4kHz
I'm leaning towards the Soundstream because It's a nice amp and I can get a hell of a deal or the Boston because it's 1ohm stereo/2ohm mono stable making it very versatile. I could use it for other applications later if I'm not happy with it in this capacity. However the Kicker is nice as well and has a 2 yr warranty.
Out of those listed, I too would choose the Sound Stream. It's probably the cleanest sounding out of the bunch.
This I have no doubt. The only other one I've heard is the Kicker, and I like that fact they they are often under-rated. But, this Soundstream, for what I can
get it for is a no brainer in terms of SQ for the $. That Boston amp just really intrigued me.
The Phoenix Gold is an incredible amp, but severely overpowered for my situation. I know details were not given, so I appreciate the time.
The Critical Mass amp, while exquisite, will undoubtedly be beyond my budget. Again, I didn't state anything about that.
The MB Quarts I am familiar with and am contemplating the Q4.150 and Q4.80. Cadence has yet to fully earn my trust, however I'm testing a 2 channel amp in my wife's car at the moment and and so far have no issues. It's nothing exceptional, but does what it's supposed to do willingly. However, it's not a top of the line series either.
I'm looking into these same amps! which would stay the coolest?? I'm assuming the Kicker would have the most power from my experience with them.
You pretty much can't go wrong with Kicker's amps.
But for SQ AND Power, I was really leaning towards that SS REF4.760. But the amp I got back will do just fine.
BreakinTHEbank
BreakinTHEbank
Oz
TxVibe
michigan born
    May 14, 2026
michigan born
    May 14, 2026
