Need a little help here.
more detail is needed. model number? are these the only things in the box? are they on the face with subs? note they can't share airspace with subs. recognize that a bandpass box does just as the name implies, it has high pass and low pass filter inherent in the design.
got a sketch or drawing of what you are planning?
First off, why are you wanting to install a coaxial into a bandpass box?
Second, why would anyone need a blueprint for this??
It would just be a matter of cutting out the hole for the speaker.....
Manufacture / Model #: SoundStorm STS40
The only other thing I have in the box is a teddy bear.
No subs planned.
sure!
http://img263.imageshack.us/img263/1008/yeahai.png
First off, why are you wanting to install a coaxial into a bandpass box?...
Do something different.
Lulz
No need for the tweeter, you won't hear it. Port length? Doesn't matter since the speaker isn't capable of playing low enough.
Enter the T/S parameters into a box program and you'll get sizing info. If you have a plexiglas bandpass box sitting around that you want to mess with, then whatever floats your boat.
Aarmin
Aarmin
Indianapolis, IN
MisterDeadeye
