Need a little bitta help here...
  • 2
SoCo
Got 2 Cerwin Vegas'
12" Dual 2 Ohm Vega Series Subwoofer
Power Handling:
Peak: 800 watts per pair / 400 watts each
RMS: 400 watts per pair / 200 watts each
Impedance: Dual 2 ohms
Someone care to tell me what would be the best amp to push em?
Im kinda on a very strict budget too considering my last setup was completely jacked minus the radio....//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
But would that be too much for 2 Subs rated at 800 peak power?
do not look at peak power. just stop! peak power is a way of selling things!
if installed and tuned correctly no. its always good to have headroom.
i had two cerwin VEGA HED's running on 600rms about a year ago....... took it like lil champs!
if it seems @ 2 ohms they are being killed, wire them in series for 8ohm load......that amp will allow you to go a little bigger the next time around aswell.
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
462
354
SoCo
SoCo
North Carolina
DonH
    May 18, 2024
    May 16, 2024
