Need a box designer for street beater
Bet on homie i will come to u if i have any problems. this box will be quite simple jus help wit the ports and supporting them. So let me get this right each port should be about 4 and sum change length wise
Huh? You confused me....
ok, the Precision ports from PE come with two flared ends, 2 couplings, and a tube. You cut the tube to the length you need, then use the couplings to put the flared ends on. BUT the supplied tubes are not long enough for your tuning, so instead of using the provided tube, you just substitute the appropriate size PVC pipe.
Oh didnt know how those ports came
Ok jason i got u now i jus looked at them on PE i see exactly what u are saying. Should i use the second flare also inside the box or jus leave it with no flare on the inside
are you forgeting to calculate in the flare? I think with those you use 2.5" of the flare as actual port...so you already have 5" in port with JUST the flares...17" tube and your at 23"....I dunno if the tube supplied is 17" or the maximum port length (tube and flare) is 17"....
937DYTBOI
TL>you
937DYTBOI
Dayton,Ohio
937DYTBOI
