Need a box design
Space I have is 17.5"tall, 39" wide, 24.5" deep.
Subs are 250w rms.
Nominal Impedance: 4-Ohm
Power Handling (Watts RMS): 250 Watts RMS
500 Watts Max
Voice Coil Diameter: 2.0" (51.6 mm)
Magnet Weight (oz): 60 oz. (1.70 kg.)
Speaker Connector: Dual 10 AWG compression
Fs (Hz): 23
Re (Ohms): 3.60
Le (mH): 3.14
Qms: 3.20
Qes: 0.62
Qts: 0.55
Vas (Liters): 191.5
Sd (cm2): 876
SPL (dB @ 1w/1m): 87
Xmax (mm): 9.0
Woofer Displacement (in): 0.148 cu.ft. (4.2 Liters)
Cutout Diameter (in): 13.85 in. (351.8 mm)
Mounting Depth (in): 6.98 in. (177.2 mm)
calebkhill
calebkhill
Phenix City, Alabama
The_Dealer
NorthFramingham
    Jun 30, 2026
