Need a box Design. I pay you $$.
Here's what I've got right now:
I can do it if your still looking for someone.
PM me if you want me to do it, I don't want to wate my time if someone else is already working on it.
Also how many and what size Aeros?
Just an fyi I had 2 10" RE SE's in 2.5 ft^3 with one 4" aero and i sounded pretty good.
FINALLY!!
God damm I was wondering if no one was on or did I piss everyone off for some reason.
I've never worked with aeros and have no idea how/where to start. All I know is my max dimensions I can build the box and what I want it tuned at (26 hz) can you help me out with some suggestions.
Your the man for the job!
OK, you need 4.295 total volume because you forgot to add for port displacement,
Also you math above is wrong. I'm assuming your 36x16x16 is outside dimensions in which case you have 4.197 ft^3 total to work with (which isn't enough room).
Thanks for looking out. Did not consider the port.
Damm you're right, I'm glad I'm not working with money today the way my math is going.
Eh, 4.197 will be fine. That's only 0.032 cu. ft. less per sub which shouldn't be too big of a deal.
528hz
Everything'sMiscellaneous
528hz
In the Space between Space in NM
BrianChia
