Need A/B class amp 2 channel 800w +
DLS Ultimate A3 $250 picked up since your local.
Might not be enough power though.. Unless you can wire down your components lower.
# RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
# Mode : AB
# Number of channels : 2
# Output power in 4 ohm : 2 x 150 watt
# Output power in 2 ohm : 2 x 270 Watt
# Output power in 1 ohm : 2 x 425 Watt
# Output power in 4 ohm bridge mode : 550 Watt
# Output power in 2 ohm bridge mode : 870 Watt
# Output power in 1 ohm bridge mode : 1200 watt
slam
slam
fort worth, tx
slam
michigan born
    May 14, 2026
michigan born
    May 14, 2026
