need 6000 watts cheap!
nathanh
i have 2 type x 12inch alpine subs... 3000 max a piece. i would like to max them... or have the ability to.
i like the sq out of the jl amp, but as far as reaching 3000 rms total, should i run 3 jl 1000? or is it better to run a single 3000 rms? if single is better, are there any good 3000 rms amps? and i think they have dual 4ohm coils. can i wire them at 1 ohm?
is there any way to pull more power out of amps?
and sq box setup?
sorry.. I'd answer this seriously but.. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
how would you run 3 amps to 2 subs?
also depending on how your enclosure is i would suggest 2 amps over one. if your box is divided you could run 2 amps easier(not that you could run 2 amps with box undivided) and if subs are in same enclosure i would say one larger amp
i would say 1000 watts to each of those subs would be more than enough imo
lol ya. who ever sold them to ya got ya on with the MAX numbers.
wrong, the type x can handle 1500 rms when gains are set correctly
nathanh
nathanh
stanwood, wa
scotty06
