Depends on the design of the "clipping" circuit and whether it is a clipping circuit or simply an indicator that illuminates when a certain voltage threshold is reached on the output.If the light is flickering that means you are already hard clipping your amp.. clip lights generally don't flash untill you are overdriving the peaks by at least 1db...
