Need 3000 watt rms amp suggestion
HK4000ds if you want alot of power cheap, AP3000.1s, Massive P3000.1 2600-2800wrms(but still), Treo SSX1500.1 or a SSX 2000.1 the SSX 2000.1 still does 2000wrms@1ohm at 7.65volts, as i was told by treo when i took a tour back in March, and will do 3kw at 12volts at 1ohm, .5ohms stable!!
So if I hook the bish up to a 9 volt battery, it is safe to assume that it will give me 2500 watts? Lawl
With a $650 budget you can get a lot of good amps. I would talk down the guy selling the brand new 2k6d.
Any idea why they rated it for 7.65 volts?
Buck
little alien on campus
Buck
Inside of a pyramid
pawn man
