Narrowed it down... 10" RE SE or 10" W7?
Souljah8574
Okay, I posted a thread about a week ago in search of an SQ sub that'll hit low and sound good. I've narrowed it down to these two subs and it'll be pushed by an eD NINe.1. Most likely will be placed in a ported enclosure. The subs will be going into a Civic hatchback and will be complimenting a set of PPI 356cs seeing about 100 watts per side.
I can get the W7 for $350 used from someone off craigslist in the area and the SE brand new for $300. What would be the better buy for my amp/setup?
For $300 and the amp that you have I would easily go order a FI Q or Ascendant Audio Havoc. They will both take the power and sound amazing. Both are great subs.
Kevin
You should be able to get 2 new re se's for $300
But 1 for 1, the se's don't compare to a w7; w7 blows them away.
If you like a clean, transparent woofer, then get the W7
If you like distortion, then get something else.
a w6 sounds 100x better than the w7 you ****tard
get 2 10" re se's, try to find the older ones, not the se/x
Where did I mention a w6? And "sounds 100x better than a w7" is personal preference.
Although, you didn't even argue my point, that the w7 is a clean distortion free woofer.
I don't give a **** if you like the w6 more, that wasn't the question you ignorant ****.
he was referring to your ignorant comment that w7 is the only distortion free woofer, which clearly isn't true. It's been beaten to death, yes the w7 is a good subwoofer, but you can do so much better for the price, or you could get same quality subwoofer for much less.
EDIT: back to the topic, you should get the FI Q instead, much cheaper than the W7, will sound just as good, and u won't be a JL Fan
With your budget I would get an Eclipse ti no questions
IMO a better woofer than the w7 and definatley the SE. They get crazy low and sound **** good doin it (especially in a hatch). 1200 watts will def get it movin, and the eD is underrated iirc.
Not trying to distract you, only trying to offer up what I feel is a better option for you
Holy ****, can any of you read?
Did I say the w7 was the ONLY at anything? No.
**** you guys get really pissy when someone recommends a w7 for anything.
Oh, now i'm the ignorant one huh?
NO WOOFER IS DISTORTION FREE, WHAT DO YOU THINK BASS IS?
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
701
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
824
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Souljah8574
Souljah8574
Honolulu, Hawaii
spencer321
    May 18, 2024
    May 18, 2024
