My Trunk SetUp
NINE FOUR 9C1
21
ATL
This is my trunk set up Built by Bernie Yost at RawCustumz out of Lawrenceville,GA
http://community.webshots.com/user/RawCustumz
Heres what i started with...
Heres what I got...
should lower it on those stocks...gives it a meaner look my neighbor has one and i like it better on stocks
dual exhaust would be nice too, i know those cars are fast
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
820
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
NINE FOUR 9C1
NINE FOUR 9C1
ATL
NINE FOUR 9C1
