My System
BuckyBoy
This system is currently in my car and came with it when I purchased it...
AMP:
SPL SERIES II 820 WATT AMPLIFIER
http://www.soundoffaudio.com/item.cfm/id/1104
SUBS:
1200 Watt Dual 12'' Bandpass Subwoofer System
http://www.lanzar.com/itempage.asp?model=HBP212
HEAD UNIT:
http://www.lanzar.com/itempage.asp?model=VBD1700
I have been planning a new system...
I just got this head unit ordered...
Eclipse CD1000
http://www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?g=300&I=099CD1000
I got some suggestions from another forum I am a member of, but nothin is final other than the headunit. I don't know alot about car audio, but I have been learned a little about it lately. I do know that I want bass, but I want it to be clear as well. If you think you have a better suggestion than this list let me know.
Subwoofer Wire-
Monster 402 XLN® XTREME Subwoofer Speaker Cable
http://www.monstercable.com/mpc/productPageMPC.asp?pin=3113&section=inter
Speaker Wire-
Monster 202 LN® Speaker Cable
http://www.monstercable.com/mpc/productPageMPC.asp?pin=3102&section=inter
Amp Wiring Kit-
Tsunami
http://cannonsoundworks.com/tsu06.html
2 Channel Amp-
Kicker 06ZX200.2
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17037
Mono Amp-
Kicker 06ZX400.1
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17031
6.5" Front Speakers-
Infinity Reference 6020cs
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18372
4 Channel RCA Cable-
Tsunami 17' 4 Channel Competition RCA
http://cgi.ebay.com/Tsunami-RTP8-94-17-4-Channel-Competition-RCA-Cable-L-K_W0QQitemZ250176418636QQihZ015QQcategoryZ94846QQcmdZViewItem
12" Sub-
Infinity Reference 1250w
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18536
Alright I took my old head unit out and found alot of wires. Please help me out.
#1
#2
#3
#4
#5
#6
#7
#8
(Sorry I took so much room with pics. I couldn't get links to work any other way.)
Alright. If I am correct #1 goes into the back of the radio. I pair the wires up on #1 with wires from #2. #2 then plugs into the plug in the dash.
In #7 and #8 what is the silver box? Also, the three plugs were not being used. IDK this is all confusin me a little. Should I just unplug most of the wires out of the dash and hook my harness up like I was sayin?
Alot of this is gonna change when I get the rest of my setup and I can get all these wires out of the way hopefully.
Wow, that's expensive for the S series. You can find a lot cheaper. In fact, you can find the higher end Type-R cheaper than that. For another $40, you can even get their top of the line Type-X set. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
http://cgi.ebay.com/ALPINE-SPX-17REF-6-5-6-1-2-TYPE-X-COMPONENT-SPEAKERS_W0QQitemZ140172355604QQihZ004QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I am glad you're not going with Infinity though.
Don't worry about wiring kits. Even the cheapy ones from Walmart do just fine. Wire is wire, no matter what price tag you put on it.
Shop around for amps. You can get better pricing for more power. Good is somewhere around 4 watts per $1. Kicker isn't a bad option, decent pricing, look on Ebay. Also check out Cadence, Hifonics, and Phoenix Gold.
Ditto on the Infinity sub. There are better options. The "right" option will depend on what you're looking for, i.e. desired box size, available power, desired output, and desired frequency range(flat frequency response from X Hz to Y Hz.
BuckyBoy
BuckyBoy
Northeast GA
BuckyBoy
