My system so far *Pics*
you might not have a good ground on your amp if you are only seeing 12 volts on the remote line. Also did you do any testing with your tweeters right there? seems a bit close to the listener/off axis.
But when i test my alternator, i put the red wire from the dmm on the postive terminal on the alternator then the black on the battery and it only reads 10.5 volts. Im using a knukonceptz ground block so i hope its not the ground.
Am i supposd to ground the distro block or ground block?
thanks guys, i figured out my problem and i feel like a dumbass. Sorry knukonceptz. I forgot to ground the ground disrto block //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
They are the best speakers i have ever heard in my life, so clear, loud, and alive.
There was 6.5's in the doors but i made that MDF ring then there was about an inch of space at the bottom and i sealed that up with wood. I just forgot to take pictures of that
Eric111e
Eric111e
Sorrento, FL
Eric111e
