My subs keep cutting out. Any idea why?
alec14
For some reason as of late, my subs just randomly cut out, or won't play until i turn the volume up on my radio pretty loud. Does anybody know what might be wrong? I thought it might be the rca's, but I'm not a big problem-solver in this area. Any help at all would be greatly appreciated!!
what're some reasonably priced, good rca's out there?
---------- Post added at 05:40 PM ---------- Previous post was at 05:39 PM ----------
bad ground of amps or headunit?
check the amp ground where its conencted and that its in the connector of the amp properly
left field idea.. but some HU have att.. which cuts your volume to 10% some of the HU will remain in ATT mode even when your turning volume up..
sony was notorious for this.
just a thought.
just a thought.
mine has that. it's a pioneer p7900bt. i'll be checking on that tomorrow, thanks. but my subs sometime kick back in at loud volumes. could this still be a grounding issue, or rca's? one or the other, possibly?
Probably ground
would it be that i need a new ring terminal? because my subs used to play fine with my ground in the same spot it's in right now. The only difference is that I've added another amp. Should I try grounding in a different spot?
If you did not have the issue until you added the other amp at that ground location, then that may very well be the culprit.It could very well be too that the ground wiring is too small,both the ground and supply should be the same size in reality.4 ga power wire and 12 ga ground wire when 4ga min for power and ground on an amp,isnt good.Ive seen this done several ocassions, and this issue is mainly been the culprit.That could be the issue as well, or not a cleand off mounting surface?Something to be considered, other than that trial and error to begin trouble shooting/ruling out
i have 4 ga. power, and 4 ga. ground, with 8 gauge split by 2 distros to both amps for power and ground. I think it may be my ground distro, it's not a super good one. but the subs were working good for awhile, then all of a sudden were cutting out at low volumes, then began cutting out at loud volumes, then altogether. could that still be ground?
---------- Post added at 01:06 PM ---------- Previous post was at 01:06 PM ----------
if you verified the ground isnt the problem try looking into the rcas
those are both my main points of concern. It could be either one
Id try bypassing the distro block on the ground/testing that to see if the block is not sufficient..wire to wire for testing to find out
Id try bypassing the distro block on the ground/testing that to see if the block is not sufficient..wire to wire for testing to find out[/
well they started working again last night, and there's no dimming of amp lights, so i figure it's not the ground. I'm thinking it's something up in the headunit, or rca's
---------- Post added at 01:34 PM ---------- Previous post was at 01:33 PM ----------
alec14
alec14
Alpena, MI
alec14
michigan born
    May 14, 2026
michigan born
    May 14, 2026
