My next system almost complete with pics
Now heres one more pic of my mnim Kicker kx200.2 birthsheet. It should go perfect wth the prows tuned right.
Next is one of my bnib SoundStream EG15-x that was replaced by SoundSteam a couple of weeks ago. Also last week I has to place an order for a Soundstream PCW 15 since they discontinued the EG and made the PCW's (Picasso) surround a little better but it looks the same and has the the same ratings. Both of these subs are dual 4 ohm so when I finish wireing them thay will ne at a one ohm load.
The new sub should be here right after Christmas.
Now lrts see whats going to drive these bad boys at one ohm in a little Chevy s-10 with the little exstended back. Sounds almost like a wall if I just double it uo.
The amp will be your typical Orion 1200D amplifier. I guess it's a good thing no one bought it here from me.
Now it's a time for a blast of the past. This is a Rare Rockford Punch G 100 Z ll amplifier. It barely used for teo days as I was told. It has everything that it came with when it was bought back in 2000 and even has the best buy reciept, RF sticker, birth certificate, extra weird looking wires and the Allon wrench and screws still unopened in the baggy. This should be kepy as a collectors item.
if they sold it at best buy, do you really think that it is rare?
Smartass. It's hard to find a amp made over 5 years ago bnib and this one is going on 7 years. Think of the value when it reaches ten years old. Thats why you see the original rf's without the box sell for so much.
I had a Kicker ZR120 biib that was 3 years old and I got retail value on ebay for it.
Sorry about the smartass comment, Merry Christmas and stay safe.
mono signal to speakers FTL. i would cut the voltage a little and use the 2 channel AS a 2 channel. 8 ohm speakers are generaly more efficent(sp?) so they may do better with less voltage
Then I should just kick out the 200.2 KX and ket a stronger Kx 4 channel. to run the mids and tweets
Bingo, I assume you are going to run these active? If so, what are you using for the active x-over. Let's see some specs for your mids.
BTW, I'm using 8 ohm mids and tweets and running them off of a PG Xenon 100.4. It gets insanely loud!!//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
My plan was to run the 125 watts x2 5.5 sunbs off of a amp as a mid sub but not going into the heartz it would harm them and not at full power either. Then I wanted to get another amp to run those ss horns at high pass off of another amp. Thing is I don't have a seperate crossover. If I had the completes set of Bostons I would just run them off the kx 200.2 and call it a day but all I have are the midwoofers.
dkc62
SoundStream®
dkc62
WPB FL and Eastern Shore VA
dkc62
