My New budget amp
Hopefully you’ll have better luck than most have with this amp ..don’t go below 1 ohm with it because it can’t take it ..it looks like the power supply isn’t strong enough to support the amps power so you may want to be fairly conservative on the amp gain ...
I have not decided on subs yet.Might try PSI Level 1 12s
Will be in 2 cubic ft sealed fiberglass
u mean 1cf per sub sealed? idk man i think those are a ported sub.. what car? u maybe better off with 1 higher level something in 2-2.5cf ad ported box.. if u been blowing amps u may wanta check amp ground b4 u get new amp, make sure it tight and no paint under it..
No waste of anything and Using Boss is a stupid statement.
The box is very high quality unit made for Dodge Ram application under the seat.
2 cubic ft is shared and many 12” subs work well with that space.
giltyler
giltyler
DFW METROPLEX
Hertz Mafia
