My mistake needs a solution
Well that was just fucking stupid...you really think that having the ground disconnected from your battery and then grounding the positive terminal with your wrench to the vehicle frame is not going to result in a flash about the brightness of the sun??? Are you really that fucking stupid? Really???? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Wow, I rarely comment on this stuff, but YES if you disconnect the negative battery terminal, the frame and body of the car is no longer a ground therefore you will not cause a spark if you have a wrench on the positive terminal and ground it to the frame. Are YOU really that ****ing stupid?
ok while i was unhooking the positive my wrench hit the metal on my fender now my car is on fire what should i have done. always unhook the ground wire first not the positive.
pull the negative, not the positive. n00bcakez
^^ this
No, just read (and wrote) it wrong. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
This is te picture to his idiotic response...you are welcome. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
To OP
Everything is a lot easier if you stand in a bucket of water, and wear some damp cotton gloves....and also never disconnect the battery its always easier to get stuff done this way. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
To OP
...and that is so "yesterday" brotato. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I love the past holmes...the future isnt to bright brah. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
GannonC27
GannonC27
Chicago, IL
The HACKER
