GLN305
Wow, I rarely comment on this stuff, but YES if you disconnect the negative battery terminal, the frame and body of the car is no longer a ground therefore you will not cause a spark if you have a wrench on the positive terminal and ground it to the frame. Are YOU really that ****ing stupid?Well that was just fucking stupid...you really think that having the ground disconnected from your battery and then grounding the positive terminal with your wrench to the vehicle frame is not going to result in a flash about the brightness of the sun??? Are you really that fucking stupid? Really???? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
