My honda project
Hii Im Justin
Holla!!!
So i picked up a little ef hatch a few weeks ago and decided to take it apart and build a motor for it.. it came with a mexi paint job, so i sanded it down and painted it beaver blood red, but i dont like it, so im just gonna camo it and gloss black the inside with a roll cage.. its gonna be my fall/winter project
its a 89 with really clean body,no dents..got it for $700 and ran fine.. had crx si interior that i ripped out
If you're planning to build a single cam, go with a Vitara build. They're the same pistons from the Suzuki Gran Vitara, super low compression and the ring lands are really far down on the piston. They love lots of boost and will soak up a lot of timing. They're the same bore at the D16's, and you can find them on eBay all day for $100, use OEM Honda rings, or Hastings rings.
Looks like a cool project, I always liked the EF hatches.
Audio Legion has a pair of tens in an enclosure left for under $200 bucks...
13
70
Polk Audio DB Series with or without an amplifier. MM Series on an amplifier
445
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
954
Hii Im Justin
Holla!!!
Hii Im Justin
vancompton,Or
Hii Im Justin
    Apr 27, 2024
audiobaun
    Apr 27, 2024
