Decado2
Got my recone kits in from Fi, 2 10" recones for Konaki motors, kits came saturday, I began on saturday.
I cut up the 2 Konaki's, one 12" and one 15", the bolts came out of the 12" easy, all but one of the bolts came out of the 15", I had to drill the head off the last bolt.
So, one of my 10's has only 5 bolts //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif , well, I used locktite thread locker on all the bolts so I guess I will be cool.
After bolting down the baskets I went to put the terminals on, thats when I noticed that on one side of one of the baskets, the hole you bolt the terminal too, was misaligned, so I could not bolt the terminal on.
Well, I refused to be stopped, so I used the terminals from the konaki on that side, they are seperate, so it did not matter that the hole to bolt it to was off.
I then mixed up the epoxy and placed it on the landings, got my envelope for a shim and dropped the cone in, the epoxy locked tight to the spiders, but would not hold the surround //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif .
So, long story short, I used a tc 7 motor to push the cone down on the glue, then applied more epoxy all over the edge of the cone and landing, (hoping that when it hardens, the cone will not seperate from the basket).
I had this problem with both subs, the epoxy would hold the spiders on contact, but not the cone, I must have chose the wrong brand for foam/plastic/rubber/ whatever the hell its made of.
So, I am pretty sure my subs are going to fall apart once I install them, at least, I KNOW the cone will seperate from the basket. I wonder is there anything I can do for that area should it not hold?
Besides ordering another set of recones //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif , well, at least the sub checks out ok, they read correctly on the dmm and they worked when I tested them with a battery.
Tommorow I am going to free air them on the HT reciever, see if they come apart off that, if they survive 100 rms, into the car and onto the kx 2500.1 they go.
My next thread will be me looking for help reglueing my cone //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif , if nothing else, it was a learning expierience //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
