My first box log. *pics*
Order 2 aero ports from Parts Express. The flares will help reduce port noise.
What length would I need if I used 4? I have the box pointing up and I dont want the ports to fire into the side of my jeep's cargo area. The front height is 14.75" outside, so 12.5 inside dimension.
Inside dimensions of box are 34.5 x 18.5 x 12.5
Your gonna need to use PVC and get 90 degree turns to put port on the sub face side cause the ports are to long.Not a biggie.
25HZ= Two ports 4" PVC need to be 25.5" long.
Youll lose output but you like the lows you try this first.
I thought it was generally said that you tune a ported box low (20's) to get the response that a sealed box would have...
...If he wants lows, he should just stick with an oversized sealed.
Comon man you know 4.4 cubes for a 12 sealed is too much:p:
i LOVE screws. They make me feel secure about the structural integrity of the box. Plus since I did it right, they are very nice. Pre drilled, countersinked, and torqued to maximum before stripping (I love torque settings on my drill, makes it so much easier)
I know you won't believe me, but putting more screws in there actually LOWERS the structural integrity of the enclosure. Even pre-drilled holes reduce it. Will the enclosure fail? No; I doubt it. Is it weaker than maybe 1 or two screws per side? Yes.
ultimate157
Engineering Student
ultimate157
Worcester, ma
Bake
