My first attempt at SQ, looking for guidance.
Driver specs, still looking for someone who knows how the variable QTS works.
Atlas 15"
Low Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .392
Qts .37
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 11.7
Spl 1W/1M 91.5 dB
Spl 2.83V/1M 95.5 dB
Le .86 mH
Cms .388 mm/N
No. .904
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
Mid Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .483
Qts .45
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 10.3
Spl 1W/1M 90.6 dB
Spl 2.83V/1M 94.5 dB
Le .86 mH
Cms .388 mm/N
No. .711
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
High Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .624
Qts .57
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 8.5
Spl 1W/1M 89.5 dB
Spl 2.83V/1M 93.5 dB
Le .86 mH
Cms .388 mm/N
No. .567
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
If DLS is too expensive then dynaudio is way too expensive. I picked up my 8's on diy forums for $200 though. If you don't mind used you can get pretty good deals. Most of my equipment in by car I bought used. If I had bought it all new I would probably have had another $2000 into my system.
I do buy 95% of my stuff used, and I have never seen DLS for $200 lol.
PaulThompson229
Professional Mooch
PaulThompson229
So. MD
PaulThompson229
