My dual sundown sa-10 ported box build.
Im not sure what your talking about as far as port placement being wrong, but i can say this...its clean sounding and no port noise so that must mean the 2010 f150 is exempt from those placement demands.
Don't worry about it...I would trust shredder and his design work.
With the seat lift, will it still stick out like 4 inches past the front of the seat?
Jeez... I hope not... the measurements given were 9" tall in front before the lift... so I used 11" when coming up with the enclosure thats in there... a 2" lift I was told... should be fine... I hope!
record a youtube video when you done. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'd like to see that... I ported it for 1/2 ohm power and it's tuned to 31hz... ought to at least rattle his change in the console... lol
Is this the guy who more or less said some pancake RFs were louder than his SAs?
Amazing what difference application makes
I cant believe lmi is actually selling those seat lift kits for that much, 7 pieces of 2x2 square tubing with 1 side cut out and a hole in it, 2 brackets to lower seat latch...i should start making a set for half that price. I understand making mooney but wow lol
If you have the tools to do it, go to the hardware store and do it yourself, and if your mechanically i nclined. Hell I would. Once you see how and figure it out, why buy it?!
I second the Ant's Alpines. This link covers placement and aiming subs. https://www.installer.com/tech/index.php?page=aiming
60
843
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
835
943
apeterson26
Memphis, tn
apeterson26
    May 18, 2024
    May 16, 2024
