it's also made out of plywood. Not really the best material for boxes.its not a bad box.. its just the carpeting. LMAO at the people who are all trippin out
isn't MDF denser than most regular plywood? Also it seems like it would be more of a PITA to work with and seal up...You haven't been "misinformed", it isn't a good material to use for sub enclosures because it's very expensive and doesn't have any benefits, but PHYSICALLY, it is fine to use.
Whatcha reckon fiberboard is, out of curiosity?I would also think that since plywood is basically a bunch of wood chips glued together, it wouldn't hold together in that kind of environment as well as a solid material. It probably wouldn't matter in most setups, but I imagine that in more extreme applications, it might pose a problem over time. Plywood isn't that hard to break really. This is just speculation and I might be way off bass, but it's something to think about.
Yes, you're quite right. The things used for homebuilding and flooring (OSB) are terrible to use, you'd be better off using particle board. What is used for speakers is high quality cabinet grade plywood, which is usually either 5,7, or 13 layers of wood pressed into one. It's very strong, but it's lighter than MDF and can resonate more. Plus, it's extremely expensive.YEah, I've never used the birch or Known anyone who has. Only plywood I've really had experience with is basic stuff used for construction. That's the kind of stuf I was referring to.
