My car
MisterDeadeye
Bannned
Seriously blows.
I have mismatched tires, with tread ranging from almost 0% to 65%. I have horrible brake pads, and warped rotors. My carpet, dash, and rear seats are horribly ruined by different people trying to take things apart without knowing what they're doing(often times, me). I have some kind of starting issue -- sometimes my car starts after it cranking for 5-7 seconds(usually not all at one time; I stop cranking and start a couple of seconds after it didn't start the first time). Sometimes the car doesn't start. I have an oil leak, either from a gasket, or my oil cap, or something I haven't considered yet(there is oil on the front of the valve cover, down by where the gasket is, but it looks like oil is coming out of the cap). If it's not the gasket or cap, then something's forcing the oil out through the cap which is even worse. Now I'm sad just thinking about it. My bumpers aren't on like they should be, and the metal pieces they're supposed to be attached to are either bent, gone, or rusted to ish. I have dents on my roof(from what, I have no idea) by my sunroof, dents on the hood, dents on fenders and quarter panels. My spoiler's adhesive isn't good, and so I've had to attach the spoiler with an epoxy. Unfortunately, I unknowingly spread the epoxy around where the spoiler goes on, and dripped it off the side. After two days, the surrounding area and side of the car had a bright yellow/brown jizz stain. My suspension is screwed up in some way, and I think I need new motor mounts.
On top of all of that, I'm still out of a job, and feel the need to get more audio for my car.
[/img]
It's a 2003 Mitsubishi Galant GTZ. I'll get pics soon, but right now I'm about to grill some jalapenos.
And it's harder to get a nicer car when you don't have a job. I'm working on fixing the car rather than getting audio right now. I just felt the need for a rant.
And Kangaroux, I just got a groan. Noooo. :/
I was just messin with ya but that's a lot of **** wrong... I have an 03 Cherokee as a 2nd vehicle and it's not nearly that bad. How many miles are on your car?
My Pontiac looks like someone shot it in the *** cus my sub knocked the key lock bracket loose and somewhere along the way the key lock fell out...who knows where that is.
How is your '03 so fucked up?>.
Well, I got it at 130k miles, and I've put 10k on it. The dents and oil leak was a problem before I got the car. I got a new valve cover gasket put on the car when I first got it, which helped for a while, but I have a feeling the person who put it on didn't torque the bolts to spec since he's all blue collar and this is isn't a Ford, Dodge, or Chevy.
The back seat was screwed up when I got the car, too. The leather dash(forgot to say that the interior is leather) had nicks in it when I got it, and while trying to take some of the trim pieces on either side of the car, I have screwed up the carpet a bit -- not really a big deal. There has always been some kind of fuel problem. We thought a new fuel pump or fuel filter would help, and it did, for a little bit. Before that we tried some relay(forgot what it was... I've had the car for a while now), which didn't work.
The spoiler and bumpers were screwed up when I got the car as well. Needless to say, I got the car cheap, but I didn't know it was in as bad of shape as I've recently started noticing. As for the tires, they're pretty expensive for someone without a job, and I've blown both front tires, so each time I got a cheap used tire. Both blowouts were at 100+ mph, which kind of ******. Anyway, my rear tires were getting pretty bald, so I bought two MORE cheap used tires.
MisterDeadeye
Bannned
MisterDeadeye
Nebraska
05fronty
