My Box Build. Do I Know What I'm Doing?
Posjr
I'm making a sub box for the apt. My goal was to get as low as i can with min. space. Right now i'm at 1cube box tuned to 24hz. This is based of a infinity ref W860. Why in 8in? I got a grumpy old lady up stairs.....
Here is a pix of the tune i did with winisd. Also its a 12.5x2in port, 25sq inch port, and I think i'm at 110in length of port.
My concern now is am i wasting my time because its an 8in?
SENSITIVITY (2.83V @ 1M): 91dB
POWER HANDLING: 250WR M S (1000WPEAK )
FREQUENCY RESPONSE: 30HZ ~ 400HZ
VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 3.30
VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH) . . . . . . . 2.31
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 33.17
SD (M2) . . . . . . . 214.00
MOTOR FORCE FACTOR: BL ™ . . . . . . . . 12.56
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 0.54
VAS (LITERS) . . . . . 15.23
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 232.70
MOVING MASS, AIR LOAD: M MS(GRAMS). . . . 124.20
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 122.40
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 29.60
MECHANICAL Q: QMS . . . . . . . . . . . 6.10
ELECTRICAL Q: QES . . . . . . . . . . . 0.483
TOTAL Q: QTS . . . . . . . . . . . . 0.45
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . .0.315
HAG (MM) . . . . . . . . 8.00
VOICE COIL HEIGHT: HVC (IN) .. . . . . . . . . 1.34
HVC (MM) . . . . . . . . . . . 34
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . 0.513
XMAX (MM) . . . . . . 13.00
Thanx
After tossing and turning last night i feel i should of went with a 10in...... You guys know any 10in subs that can be in a 1cube box? Rms under 500@4ohms Price under $200.....
I'm not trying to be loud just want to feel some 25hz. I'm not sure if this 8in will put out enough!
Also i have gone through a list of subs at 10in and cant get lower than 1.8cubes.
I wouldn't be afraid to use an eight.... Btw, your enclosure looks nice. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Posjr
Posjr
San Jose
Posjr
