Another clamp test. He did not scope it but he did mention that he ran it full tilt for 2 hrs before the test and it wasn't even hot, and sounded clean so he assumed no clipping...
So tonight we took a few hours and sdelthon and myself did some testing on one of my Audiopipe AP3000Ds, I havent clamped one of these for some time now, and wanted to do a nice lil test and result page about them!!
Car used sdelthons 94 T-Bird
Deck used Sony CDX-GT63UIW 2volt preouts
Stock ALT
1 run of 1/0 Audiopipe power
2 Treo SSX100Bs and a Treo SSX75B
1 Ap3000D
2 Treo SSPs 10s dual 2s reading slightly different, final ohm load before rise coming out at 3ohms
Ohm Load calculated after imp rise
So after 2 hrs of play time and a weak charging system the amp is still very strong, and if we could hold in that 14volt range at 2-2.5ohms we will be able to get all of 3kw+ like rated then some, so for $299shipped with warranty these are the best amps on the market for the money, and ill be running 4 of them!!!
Audiopipe AP3000s amp gain lil below half
Test#1
Resting voltage-12.50volts
Voltage drop-11.6volts
Power-2014.32rms wattage
Ohm load-3.77
Amps Voltage-87.2
Amp Current-23.1
50hz test tone
Deck sublevel at +6 out of 10
Volume 30/50
Test
#2
Resting voltage-13.88
Voltage drop-12.5volts
Power-2489rms wattage
Ohm load-3.6
Amps Voltage-95.0
Amp Current-26.2
50hz test tone
Deck sublevel at 10 out of 10
Volume 30/50
Amp gain lil over 1/2
Test
#3
Resting voltage-13.83
Voltage drop-12.5
Power-2675.34rms wattage
Ohm load-3.7ohm
Amps Voltage-100.2
Amp Current-26.7
50hz test tone
Volume 30/50
Final test with video
Resting voltage-13.66
Voltage drop-12.4
Power-2525.95rms wattage
Ohm load-4.208
Amps Voltage-103.1
Amp Current-24.5
50hz test tone
Volume 35/50
