My amp skips
turtlechan
ca
I am using regular wires to wire up my amp, those very thin ones, since I don;t have the budget to buy the 4 gage wire... is that the reason my amp skips... but the low voltage indicator didn't light up... I really need some help!!!
I would say your amp isn't recieving a good signal either from a bad connection, too small of power wire, or both...If you are running very small power wire you might want to fix that, it will sound a lot better and probably aleviate your problem
Keep it Loud!
JELLYDIME
if you have it bridged and are running your amp for a long time it will start to get hot and fade in and out. place your wires next to each other in the terminals right next to each other not space everyother terminal.
turtlechan
turtlechan
ca
gurupimp6969
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
