My amp is draining the battery while parked?
There is another way to trouble shoot it
Those of us who can't replace the stock HU's run a fuse tap as the remote wire
Its a $10-15 part from any auto supply shop
https://www.canadiantire.ca/en/pdp/littelfuse-mini-add-a-circuit-fuse-holder-0201615p.html
You just disconnect the the remote wire from the back of your head unit and run it to you car's fuse box
Take the tap and pull a fuse that doesn't stay on RAP
I usually use the sunroof or the wipers
Attach the wire to to the tap and put the fuse you pulled plus another 5 amp fuse into the tap
Now plug it in to the spot where you pulled the fuse from and bob's your uncle
It will either work and the problem is solved or if it doesn't then the problem is with the amp and not the HU
Thats a good resource Kickstand, I didn't know something like that existed. A lot of good information on this forum! Thank you!
SteveG
CarAudio.com Newbie
SteveG
York PA
SteveG
