thizzkid
lets see, i have a ford 1995 explorer 4 door
-stock motor craft F5DU alternator
-higher end walmart battery, with 1000 cold cranking amps
-big 3, 4 gauge power wire from the alternator to battery, 4 gauge ground(chassis) to battery.
-4 gauge amp install kit from ebay, with a 100 amp AGU fuse
-2 12" pioneer ts-w308D4 subs, 400 watts rms per sub
-dual ported sub box, i bought it from here, http://www.techronics.com/caraudio_9983_Ground-Shaker-SQP212-12-inch-Dual-Slot-Ported-Box.html?aff=72182&CFID=3294423&CFTOKEN=70015299 check it out see how it looks
-Soundstream PCA-1500D amp- 800 watts rms at 4 ohms -bought refurbished from
SOUNDSTREAM PCA-1500D MONO BLOCK D 3000W Amplifier: VMInnovations.com
should i be ok? do they have good refurbished products?
Do you guys think i should make any changes to my setup?
im putting this setup in my car tommorow, i want my subs to play at 4 ohms should i be fine?
how bout a capacitior? should i get one if my lights are dimmings? also i heard they are bad for yours system, if so whats the point of having them?
thanks guys, any feedback is apreciated
