tsenfw
Have this component amp to put it and it looks like it's not gonna fit under the passenger seat. Any ideas where to put this thing besides the trunk?
Anything between 12-16 gauge will be fine.2000. Yeah, I have my sub amp on one seat, I'll probably have to put the component on the other. Wish I could find another spot so I don't have to run so much wire back and forth. What gauge should I used for the components from all the way back there?
That is true. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifUse a rear seat delete kit and put the amps under it. The only people that could ride in the back of a Mustang are midget children anyway. Man, I miss mine //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
That's is exactly how I have my rack now... stops like 2-2.5 inches below the rear deck.Here is a pic of the amp rack I had at one time in my 96 Mustang....It looks as if it goes all the way up...but it doesn't ...It stopped a few inches below the rear shelf so the subs could vent back in the cab....I had a custom box built for 3 RE 10's ...where I had full use and access to my spare...The amp rack was back lit by orange LED strips that could be switched on or off...most people liked it that saw it....
I don't think he had it ported into the cabin, but rather kept the seats folded down and left a space (vented area) above the amp rack for the subs to breathe into the cabin. That is just a guess though.Pretty nice. Do you still have a pic of the inside of the trunk and the ports into the cabin? I have a 2.0 cu ft box in there now and still able to access the spare, don't know how you fit 3 10's! lol
x2... For the most part. I actually have mine set up where my amp rack is identical to the one above and I have my enclosure (1.25 sealed, double baffle) tucked right behind my amp rack. But if I remove the 4 "L" brackets holding my enclosure to the trunk floor (1/4" plywood) I can fit it through the exterior trunk opening (barely). I couldn't do this with my old enclosure... I had to do the whole back seat frame removal. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gifNot that easy on mustangs. Have to take the rear seats out in order to put in larger boxes. The trunk opening from the outside is very small and you can't take the box out that way either. There's no room really to move it out of the way of the spare either.
