Multiple subwoofers
vroomy
Hi. Im looking at doing a system in a toyota pickup extra cab. I have a power hx2 15" but am thinking of going 4 10" instead. My questions are
1. When running multiple drivers sharing the same enclosure does the enclosure need to quadruple in size or not necessarily?
2. Ive got around 2-3 cubic ft for a box, what 10"s out there will work well in that box with 4 drivers and ported?
Im after some huge bass that still sounds good, got around 1000w rms in clean a/b power
you are sadly mistaken if you think you can fit anymore than a single 12 in that airspace. four 10s would require 5-6 cubic feet AFter displacement aka after subtracting how much space the wood, port and sub takes up.
If you are planning on going sealed boxes, thats a no no. Sealed boxes are horrible in trucks if you are going for anything moderately loud.
I had 4 10's before the 2 15's replacement. The enclosure was 5 cu ft internal, ported...but the outside will always look bigger. The internal volume is what counts.
vroomy
vroomy
Australia
Jeffdachef
