Mtx And Fosgate
  • Thread starter Unregistered
  • Start date
  • Replies 4
  • Views 995
  • 4
U
Unregistered
Guest
I HAVE A FORD EXPLORER.WHAT WOULD BE LOUDER??? 2 PUNCH HX2 12'S WITH A PUNCH 800.2 AMP OR 3 10 INCH MTX THUNDER 6000'S WITH 600 WATT AMP?? THEY COME OUT TO BE ABOUT THE SAME PRICE.
i agree with rangerman i hve 2 hx2s and they bump pretty dam good but 2 12's i think would be better the 10's will give you a cleaner sound. if you do end up goin with the mtx at least upgrade to the 8000.
I have a question. I have just bought one 12" rfr 3112(power hx2) It has 2 2ohm voice coils. now my question is, how do i wire them for 2 ohms???
I was told you cant wire them for two ohms. only 1ohm or 4ohms. I bought the rockford bd1000.1 amp to power the sub. it gives off 500 watts at 4ohms but i want to give them the 1000watts the amp gives at 2 ohms.
2 12"s, you'll not be disappointed if you hit the right enclosure for that... its gonna rock.. RF, MTX both good brands, you'll not regret getting either of the two
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
768
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
10
Guest
m83x
    May 16, 2024
    May 16, 2024
